Heater Hose Bracket @ Alt.. - NCRS Discussion Boards
  • James C.
    • July 4, 2012
    • 81
    I am replacing the heater/radiator hoses. The car never had the proper clamps, etc....
    Need some help - the bracket that the hoses route thru at the alternator, is the clamp
    attached to the bolt running thru the alt. or attached to the alt. bracket that is attached
    to the exhaust manifold?
    Also the lower hose(smaller) exiting the heater, when to you roll it over so to speak
    so as its the top hose heading to the engine, before the overflow/expansion tank
    or after?
    Appreciate the help.
    Car is a 64/365HP
    Jim
  • Don H.
    Moderator
    • June 16, 2009
    • 2268
    Re: Heater Hose Bracket @ Alt..
    Bracket attached to the exhaust manifold. AIM 1 Assembly B6.00 Heater hoses shows the routing, and the bracket in special views A and B.
    Be sure that your stubby hose off the Harrison tank bottom is no more than 2 1/8" and place the Tee at 45* to level.
    • James C.
      • July 4, 2012
      • 81
      Thanks Don. Looks like it's on the furthest toward the radiator bolt.
      Appreciate you help.
      Jim
      • Don H.
        Moderator
        • June 16, 2009
        • 2268
        Jim
        the bracket does not attach to one of the large bolts.
        A small bolt something like 10/24x1/2 holds it to the alternator mount.
