The Al Knock door panels of my 63 Coupe have approximately 20 fasteners that CC calls Door Panels Grommets (attached photo # 1) They are approximately 1/4 " long tubes that are flared on one end facing the inside of panel to accept the screws. My question is do the phillips screws have ferrels or trim washers (photo #2 attached to them that fit into the so called grommets or do the screws alone fit into the panel grommets?
C2 Door Panel Fasteners
Re: C2 Door Panel Fasteners
Gene, the ferrels are part of the factory door panel and just a oval head phillip's head screw. I am not sure if the reproduction door panels have the ferrels pre installed or not.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Al Knoch 1963 deluxe coupe door panel still in the plastic bag right out of the box...Attached Files- Top
