63/64 Steel Wheel - NCRS Discussion Boards
63/64 Steel Wheel
  • James C.
    • July 4, 2012
    • 81
    63/64 Steel Wheel
    Need some help - how should the 63/64 original steel wheels be marked for date?
    I have found sets w/numbers stamped near the valve stem but some not. Want
    to get at least an original for a spare but want to get the right wheel for judging.
    Thx.
  • Joe R.
    • July 31, 1976
    • 4551
    Re: 63/64 Steel Wheel
    And article published in "The Restorer" several years ago outlines the correct wheels including dating for the C-1 thru C-2. Several years ago but it can be found by searching on the CD's available from the NCRS.
    JR
    • James C.
      • July 4, 2012
      • 81
      Thanks Joe, appreciate the help.
        • 6942
        Jim, 63/64 wheels where date stamped on the inside of wheel, I believe that sometime in 65 the date started appearing at the valve stem.
        • Dan A.
          • May 31, 1974
          • 1074
          I respectfully disagree. Original wheels did not receive stamps of any kind by the valve stem hole outboard side until sometime in the 1967 model year.
            • 6942
            Dan I was not sure. thanks for the your input.
