1963 Corvette battery tray bolts - NCRS Discussion Boards
  • Richard G.
    • July 31, 1984
    • 1718
    There seems to be another difference on the 1963 Corvettes, the battery tray retaining bolts.
    Later years seem to have bolts similar to the bolts used on the lower front shocks.
    The ones with a single integral captive washer, without a separate flat or lock washer.
    My 63 has 5/16 X 7/8 NC bolts with a captive lock washer and a separate one inch outside diameter washer.
    They take a standard 1/2 wrench.
    They also have the anchor embossed on the heads. It was difficult to photograph.
    Something to do with too much battery acid over the years.....
    Every single catalog I have looked at lists only one bolt and it is the later style one.
    My Corvette is a late December car. Is this consistent with other early 63's?
    If this is in the judging manual I failed to find it.
    I am included pictures of my recently black phosphate battery tray bolts and washers.
    If anyone has any ideas were to get one of these bolts let me know as one broke off when I removed it.
    Has to be another usage, possibly on an early Impala battery tray?
    Rick
    • 43248
    Re: 1963 Corvette battery tray bolts
    Rick------
    All 1963-67 Corvettes used battery tray bolt GM #3719206. This is a 5/16-18 X 7/8" bolt with captive split lockwasher. It is black phosphate finished.
    • Richard G.
      • July 31, 1984
      • 1718
      Thanks Joe, I should have known better as my only source of information seems to have been be the catalogs. (10 wet noodle lashes)
      Imagine that, vendors selling an incorrect part!
      It would be interesting to see what a Corvette looked like with all Vendor designated "Correct Parts".
      Hopefully this post will set others straight. Thanks again for your input.
      Keeps us amateurs from making dumb mistakes....
      Well sometimes anyway.
      Rick
      • Timothy B.
        • April 30, 1983
        • 5196
        Richard,
        That bolt seems to be there (catalog) go to bolt for many applications.
        Of course that is no where correct for any 63 application that I'm aware of as the flat washer is supposed to be serrated.
