66 Dash Harness - NCRS Discussion Boards
66 Dash Harness
  • Jim S.
    • March 1, 1986
    • 1408
    66 Dash Harness
    Yet another wiring question
    Can anyone tell me where the wire labeled in the pic bellow (????? A/C Heater SW. ) goes . I have everything else in that picture figured out but that wire .
    Is it yet another "not used with A/C cars" wire ?
    Thanks ,
    Jim
  • Richard S.
    • February 1, 1984
    • 85
    Re: 66 Dash Harness
    I believe that that plug will go directly to the blower switch on a non a/c car. If car has a/c the separate wiring that goes through the firewall for the a/c components has a plug that fits the blower switch with a jumper wire on it that this plug is plugged into,so that plug is used in both non a/c and a/c cars.
    Ric
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11356
      Re: 66 Dash Harness
      Yes I just checked AIM UPC 12 Wiring Diagram. It shows a #14 Brn going directly to the Heater Switch.
      • Jim S.
        • March 1, 1986
        • 1408
        Re: 66 Dash Harness
        Both Richards ,
        Thanks for those replies .
        So that wire plugs into the pigtail of the blower switch on A/C Cars . As with most things, a good explanation helps it makes sense now !
        What threw me is I have it coming out the right of the console and it needs to be way left . That and the fact that those excellent pictures I have , and have followed religiously , were a little vague on that wire as well .
        Moving forward until the next dilemma !
        Jim
        • Jim S.
          • March 1, 1986
          • 1408
          Re: 66 Dash Harness
          Well I just went to attach and it turns out that you can't attach the two as currently configured .
          Turns out the guy who assembled the harness reversed the female adapter on the pigtail. That is to say they inserted the wire in from the adapter side and left me to install the other wire and it's male attachment in from the smaller wire side !!!!
          Note pics below and reversed adapter on bottom arrow . worse yet is I have no idea how to remove that type of adapter from the wire. It is not like the male adapters .
          Easy enough to cut and reinstall a new adapter if it wasn't up under the dash !!!
          If it's not one thing it's another !!!
          • Richard S.
            • February 1, 1984
            • 85
            Re: 66 Dash Harness
            Evening Jim....You are absolutely correct that plug is backwards. The metal connector soldered to the wire inside the plastic plug has a tang that holds it in place. Try and slide a very tiny screwdriver or ice pick in from the end the wire is not coming out from, and as you have the driver inserted try and pull the connector out gently while pulling on the wire. You may have to try both sides until you release the tang. Good luck, sometimes things just never go right. Ric
            • Joseph S.
              National Judging Chairman
              • March 1, 1985
              • 917
              Re: 66 Dash Harness
              Jim, That wire plugs directly into the Heater switch above the radio. NOT into another wire connector. It is the Power feed for your Blower motor speeds.
              • David Z.
                • April 1, 2002
                • 182
                Re: 66 Dash Harness
                Here is some info from a document that Tim Welch (another forum) and I put together on dash wiring for mid-years a while back. It shows the connection of that single brown wire to the rear of the blower motor switch.
                That pic in the OP's original post is from the dash harness that I installed in our '65 AC car. The connections are different as the 65 harness had blower motor connections coming from the engine harness and some of the dash harness connectors were just not used (taped off and stowed).
                Hope this helps.
                Dave Z
                Dave Zuberer
                • Jim S.
                  • March 1, 1986
                  • 1408
                  Re: 66 Dash Harness
                  Joe ,
                  A/C cars have an additional Harness, and as you can see from the picture , it wants the brown power wire to plug into the pigtail provided , as the heater switch terminal is already taken by the brown wire on the A/C harness .
                  Dave ,
                  That was your picture ? Then that one , and the others I used on the" left" and " Right" side as well as the cluster , in color , all labeled and arrowed , were fantastic !!! In fact you can see a few of them in the picture . It turned what seemed like an impossible task into a manageable, step by step procedure . Thanks a ton for those !!!!
                  Jim
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11356
                    Re: 66 Dash Harness
                    I forgot.... this is a AC car.
                    Yes whoever assembled that plug installed the terminal at the wrong end. No wonder it was confusing.
                    • Richard M.
                      Super Moderator
                      • August 31, 1988
                      • 11356
                      Re: 66 Dash Harness
                      • David Z.
                        • April 1, 2002
                        • 182
                        Re: 66 Dash Harness
                        Hi Jim.
                        The photos you have were from when I rewired our 65 AC/PG/PS/PW coupe. being "anal" I did not want to screw up the installation since this was the first car I ever rewired front to rear. So, I labeled everything in sight and followed the wiring diagrams to ID connectors, etc. That brown wire with the ???? on it was one that gave me some pause.
                        I'm glad those pictures were of use to you.
                        I have attached the full document that contains the Tim Welsh info from his 66. We made a heroic effort to try to document the "non-cluster" dash wiring for the mid-years. We also produced a document for the "cluster side of the harness". That one is too large to post here.
                        Dave Z
                        Dave Zuberer
                        • Richard M.
                          Super Moderator
                          • August 31, 1988
                          • 11356
                          Re: 66 Dash Harness
                          Dave, You guys did a great job on that.
                          Jim, Page 16 of the PDF shows that connector.
                          • Jim S.
                            • March 1, 1986
                            • 1408
                            Re: 66 Dash Harness
                            "I'm glad those pictures were of use to you."
                            Dave , They were Way More than just "use" to me . And I am sure the "Non Cluster PDF will come in handy as well !
                            Thanks again.
                            Jim
                            • Jim S.
                              • March 1, 1986
                              • 1408
                              Re: 66 Dash Harness
                              "Yes whoever assembled that plug installed the terminal at the wrong end. No wonder it was confusing."
                              Not to mention frustrating and time consuming.
                              Thanks Rich,
                              Jim
