Help with Block I.D. please - NCRS Discussion Boards
  • Bryan W.
    • December 1, 2003
    • 52
    A good friend has a beautiful 56 with a non original block and have been helping him ID it. It's casting is 3970010 with date code K203 and has the block stamped CL3A47916.
    Im thinking its a 350 cu in cast on the 20th November 1973 in Saginaw and assembled in the Flint plant. In my Corvette books I cannot find reference to the stamping CL3A, only CLA.
    Can anyone tell me what GM vehicle this block was first fitted to?
    Thanks Bryan
    • 43263
    Re: Help with Block I.D. please
    Thanks Bryan
    Bryan-----
    Casting number 3970010 is a 350 block and it was cast on November 20, 1973. 3970010 blocks were manufactured between late 1969 and 1980.
    As far as the stamped code goes, this is not a code that was used on any PRODUCTION engine installed in a vehicle. This was originally some sort of SERVICE engine.
    • Mike F.
      • April 25, 2011
      • 668
      Is it possible the block is stamped CE3A47916? CE3 would be an over the counter or warranty engine for 1973.
      • Bryan W.
        • December 1, 2003
        • 52
        Thanks Joe
        • Bryan W.
          • December 1, 2003
          • 52
          Ill double check with him, thanks for the reply.
          • Edward M.
            • November 1, 1985
            • 1922
            If it really is CE (and not CL) the rest of the numbers make perfectly good sense.
