C2 Transmission output shaft seal - NCRS Discussion Boards
  • Ed S.
    • August 6, 2014
    • 1377
    Need advice / recommendation for the correct transmission output shaft seal (rear seal) for a 64 close ration 4 speed. According to one source the correct GM part # is (was) 1243402. I say "was" because I can't find that part # now under any GM listing.
    I have had difficulty cross referencing that GM # to a named brand replacement seal. I have found rear seals by a number of brands but I am not sure I have the correct seal. Timken has a seal and the part # for that part on their website is 9613S.
    Can anyone confirm that is the correct seal - it is available from Rock Auto, for a few dollars plus shipping. Or, can someone recommend a source, including part # for a correct output shaft seal for a 64.
    Thank you
    Ed
  • Richard G.
    • July 31, 1984
    • 1715
    Re: C2 Transmission output shaft seal
    Walk into your local automotive transmission shop they will have one. Same seal as the Power-glide and the THM 350. Every rebuild kit comes with this seal and every 4X4 they rebuild has a seal they don't use. My guess is they will treat you well. Close ratio and wide ratios all take the same seal.
    If you were looking for a part number check the National part number 450308 Oil Seal, or Timken 9613S.
      • 43219
      Thank you
      Ed-----
      The current GM part number for the seal is GM #8673526. However, it's likely exactly the same seal as National 9613S.
      • Ed S.
        • August 6, 2014
        • 1377
        Richard, Joe,
        Thanks for the quick reply and confirming that the Timken 9613S is the correct seal. I will go with that.
        Ed
        Ed
