Glass - Removing scratches - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5345
    Just looking for some thoughts.
    I have a spare set of rear 63 glass with some scratches. I started with black 1500 grit paper and water. No affect.
    Anyone have a grit number to start at or a good process to follow?
    Thanks.
  • Guest
    Re: Glass - Removing scratches
    Harry - check the following link and see if it makes sense - have used the process in the past and seemed to be otay
    Research new car prices and deals with exclusive buying advice at CarsDirect.com. Read expert reviews, get help with auto loans and search over 1 million used listings
    • Michael J.
      • January 27, 2009
      • 7168
      I used the Eastwood glass polishing kit, it worked great, but takes lots of time, patience, and attention to being gentle.
      Avoid costly windshield replacementby removing scratches, haze
      • Frank D.
        • December 27, 2007
        • 2703
        Most of the kits are cereium oxide and take some serious elbow work....and a bit of care not to overheat the glass...
        If the scratch is light you can be successful; if its deep you'll prob get some distortion in removing it, not good on a windshield, on other glass not so much. Its a messy job too.
        • Dennis C.
          • June 30, 2002
          • 888
          Do a search on the discussion board. A few years ago someone posted a good how to article on polishing scratches out of a windshield.
          Dennis
