1965 350 HP Engine Picture - NCRS Discussion Boards
  • Dick G.
    • May 31, 1988
    • 681
    Can someone post a picture of their Correct 65 350HP Passenger side of their engine?
    I need to order the new JG.
    Thank You
    RG
  • Keith W.
    • June 30, 1998
    • 375
    Re: 1965 350 HP Engine Picture
    RG - here's a few pictures, if you need something more specific let me know etc - all the best Keith
    kjswillcox@btinternet.com
    • Richard L.
      • May 31, 1988
      • 156
      From a few years back...
      • Dick G.
        • May 31, 1988
        • 681
        Thanks Guys
        I appreciate it.
        DG
        • Dick G.
          • May 31, 1988
          • 681
          Does this Black vacuum hose running over the top of the valve cover attach to the nipple on the bottom of the base of the air cleaner?
          Where does the associated metal tube running up past the exhaust manifold come from? What is it called?
          My corvette is missing these 2 items.
          Thank You
          RG
          • Jim T.
            • March 1, 1993
            • 5351
            Keith what is the purpose of having two nuts on the bolt coming from the fan clutch in your picture?
            • Leif A.
              • August 31, 1997
              • 3644
              He doesn't...the picture #4 has the two studs in perfect alignment appearing as two on one. Look at picture #2.
              Leif
              • Jim D.
                • 2885
                Optical illusion. Look closer. There's only 1 nut per stud.
                • Keith W.
                  • June 30, 1998
                  • 375
                  RG - I've always know it as a choke tube - hope that helps
                  • Jim T.
                    • March 1, 1993
                    • 5351
                    Thanks Leif. I do see now my vision error. Thanks
