fly wheel - NCRS Discussion Boards
fly wheel
  • Frank K.
    • January 1, 2000
    • 319
    fly wheel
    Should the flywheel be turned on each clutch replacement? What would stop the flywheel from being turned? Should it be balanced? Is there a advantage when a new one is used?
    • 43248
    Re: fly wheel
    Frank------
    I do not recommend machined flywheels on any Corvette unless there is absolutely no other option. The clutch system on a Corvette is just too "touchy". After machining a flywheel you may find that clutch adjustment becomes problematic.
    What would prevent a flywheel from being machined? If it's already been machined to minimum thickness or if heat cracking cannot be removed by machining.
    I always recommend that the flywheel, pressure plate and disc be balanced whenever any replacement or machining occurs.
    There's a big advantage to using a NEW OEM spec flywheel. It should always be balanced as described above.
    • Frank K.
      • January 1, 2000
      • 319
      Re: fly wheel
      Thanks! Is there a part number for the gm fly wheel for my 77 L-82 car? Thanks Frank
        • 43248
        Re: fly wheel
        Frank-----
        GM #3991469.
