1967 Corvette BBC Upper and Lower Radiator Hose Part #s - NCRS Discussion Boards
  • Daniel S.
    • January 14, 2011
    • 309
    Hi All, what are the assembly line parts #s for upper and lower radiator hoses used on '67 big block Corvettes?
    Do the heater hoses and bypass hoses have specific identifiable part numbers too? Any help would be great.
    Dan
    • 43293
    Re: 1967 Corvette BBC Upper and Lower Radiator Part #s
    Dan
    Dan------
    I believe the upper radiator hose was GM #3906615 and the lower GM #3882826.
    • Daniel S.
      • January 14, 2011
      • 309
      Thanks Joe. Much appreciated.
      Do you have similar info for the bypass hose or heater hoses?
      Dan
        • 43293
        Dan
        Dan------
        I just don't recall on those and I'm out-of-town so I can't check my references. I don't think the heater hoses had a GM part number on them but they probably had some sort of printing. The bypass hose I just don't recall.
        • Tom D.
          • September 30, 1981
          • 2151
          Dan: Be aware that the AIM (Assembly Instruction Sheets) may list a GM number different from the Service Part Number. The service part number might be a "kit" number, including clamps or an instruction sheet and etc. The service part number could also have been changed over the years, as more (later) engines were "serviced".
          I am typing all of this without looking at my copy of the AIM. Sorry it is not near me at the moment.
          https://MichiganNCRS.org
          Michigan Chapter
          Tom Dingman
            • 43293
            Tom------
            Radiator hoses for Corvettes were not supplied as kits. So, the SERVICE part number was the same as the PRODUCTION part number.
            The part numbers I supplied were the original part numbers. However, it's possible that very early 1967 used a different upper hose part number. I doubt it, but it's possible.
            • William F.
              • June 9, 2009
              • 1364
              Are ones with original PN's still available from Chevy or doe you get to get repo ones from Doc Rebuild?
              • Leif A.
                • August 31, 1997
                • 3658
                Go online to the good Doctor and order your hoses...you won't be disappointed. His products are spot on...and, quality to boot.
                Leif
                  • 43293
                  William-------
                  Neither of the 1967 BB radiator hoses are available from GM as they were GM-discontinued quite some time ago.
