1967 38866093 L88 Intake??? - NCRS Discussion Boards
  • Edward B.
    • March 29, 2013
    • 691
    The L88 was introduced around February, 1967, but I have a friend that found a 3886093 intake with a 12-2-66 date (see attached). However, the casting number is 38866093 not 3886093. Anyone have any comments?
    Ed
  • Leif A.
    • August 31, 1997
    • 3631
    Re: 1967 38866093 L88 Intake???
    That doesn't appear to be an original cast part number, IMHO. If you look closely, you can see the original 7 digit cast numbers underneath the overlay of new numbers.
    Leif
    • Rick A.
      • July 31, 2002
      • 2147
      I agree - Run Forest Run!!!!
      Rick Aleshire
      2016 Ebony C7R Z06 "ROSA"
      • Peter Z.
        • May 31, 1986
        • 11
        Jan 67 dated intake
        • Edward B.
          • March 29, 2013
          • 691
          Thanks Peter. What's the date on that intake?
          Ed
          • Leif A.
            • August 31, 1997
            • 3631
            Ed
            Ed,
            Peter shows it to be a January '67 date right next to the picture.
            Leif
            • Edward B.
              • March 29, 2013
              • 691
              OH!! Didn't even see that. Thanks.
              Ed
              • Larry E.
                • 1677
                Hay Joe Lucia>Could that top picture be some type of "Prototype"?? Larry
                Larry
                LT1 in a 1LE -- One of 134
                • Mike M.
                  • May 31, 1974
                  • 8389
                  larry: thats what i'm thinking too. mike
                  • Edward B.
                    • March 29, 2013
                    • 691
                    And that's why I initially posted the thread. The date (December 2nd, 1966) is a good indicator that this intake is a pre-production prototype and a mistake (?) was made on the casting number. GM cast prototypes are cast with an O DASH (O-) number but I don't know how Winters handled prototype castings. I was hoping someone with an inside contact to Winters might have an answer. It could be just a simple mistake (probably) and was fixed on the next prototype and production manifolds. Peter shows his manifold as a January, 1967 casting, but he didn't say the day. I'd like to hear from anyone else with a late 1966 or early 1967 3886093 to see what they have.
                    Ed
                    • Michael W.
                      • April 1, 1997
                      • 4290
                      Several intakes with the extra 6 in the casting number have been found over the decades. Error?
                      • Edward B.
                        • March 29, 2013
                        • 691
                        Mike, does this apply to the 3886093 intake or some other?
                        Ed
                        • John D.
                          • June 30, 1991
                          • 875
                          Could one be turned into the other with the plenum divider removed or were there other differences ?
                          • Dick W.
                            • 10483
                            Plenum divider was factory cut beginning mid? '69. Chevy Power circa 1968? book shows how to do a field modification. There was a problem with fuel distribution
                            Dick Whittington
                            • Peter Z.
                              • May 31, 1986
                              • 11
                              The manifold I show did not appear to be separately milled out. I have seen over stamped 069 (with 093) manifolds hand milled however. I could be foggy on this at this time, however. It is now in my old 1967Corvette serial #3254, an old Briggs Chevrolet stickered coupe, which I sold 2001.
