C1 brake hoses 1957 - NCRS Discussion Boards
C1 brake hoses 1957
  • Dan P.
    • December 1, 1990
    • 683
    C1 brake hoses 1957
    Were the original fittings on the rubber brake hose Yellow Cadmium or Silver.
  • Mike M.
    • May 31, 1974
    • 8400
    Re: C1 brake hoses 1957
    although i'm not certain, i had mine silver cad plated. mike
    • Dan P.
      • December 1, 1990
      • 683
      Mike trying to figure out what is natural and what is painted on the front suspension on a 57.
      spindles
      knuckles
      A arm shafts
      3rd arm bracket I see were you said you painted them
      Idler arm
      drag link
      do you cadmium plate the hardware that is visible on the backing plate . Stud with large nut ,bolts that hold the wheel cylinders . nails that hold brake shoes.
      Do you put the inspection marks on top of the black paint .
      • Mike M.
        • May 31, 1974
        • 8400
        dan: our 1957 vin 4450, which i restored in the late 80's and duntoved at anaheim in '91, 1957 vin 1093 which i restored and duntoved at charlotte in 2010, as well as 1957 vin 5655(which dick robinson restored about 10 years ago) all have black overspray on the parts you mentioned in your post above. vin's 4450 and 1093, the front suspension parts of which i glass beaded, had no inspection paint marks on them. i believe that some 57's had paint markings but am convinced not all had the paint markings. if they had paint markings, then it'd be under the black painted front suspension parts. the only c-1 i've restored, a 61 RPO vet, had paint markings under its original black paint but it wasn't visible till i glass beaded the individual pieces. in this case, the paint markings were directly applied to raw, unpainted suspension parts then blacked out . good luck restoring your 57. regards, mike
