Does anyone sell the battery mounting studs that are riveted to the trans tunnel? - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1396
    Guys,
    I was taking off the positive battery cable of the car and I snapped one of the studs that are riveted to the trans tunnel. Does anyone know if these are sold anywhere? I've looked at several of the vendors and can't find them. Thanks.
    Mike
  • Rick N.
    • August 25, 2017
    • 141
    Re: Does anyone sell the battery mounting studs that are riveted to the trans tunnel?
    I have replaced them in the past.
    I don't remember at this moment but I will look into where I got them from.
    • Michael C.
      • May 3, 2015
      • 55
      Paragon sells them. Had to replace a few of mine.
      https://www.paragoncorvette.com/p-35...tener-kit.aspx
      • Gene M.
        • April 1, 1985
        • 4232
        I've always made them using a flattened out original as a pattern and cut it out of 1/32" sheet metal with tin snips. Drill a couple holes and bend up ears ......... done. All that left is rivet them in and bend over ears thru the insulation.
        Oops wrong clips but just as easy to tack weld a stud on a cut out strip with three holes as original. And rivet them in........ my bad!
