Need info from the '67 CSM - NCRS Discussion Boards
    • 15706
    Can someone with a '67 CSM look at section 6M, idle speed/mixture adjustment procedure, and tell me what the initial recommended idle mixture screws setting is for the L71 427/435 HP engine center carb... number or turns out from the seat.
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11360
    Re: Need info from the '67 CSM
    Duke, I don't have one handy but recall initial is 1 1/2 turns out.
    I have a few jpg copies of the CSM and it states the the 2300C initial adjustment is the same for all other Holleys.
    edit..... Also just googled this and got it from the Holley website. It too states 1 1/2 turns. (Step2)
    https://forums.holley.com/entry.php?...n-Holley-Carbs
    • Larry M.
      • January 1, 1992
      • 2701
      Duke:
      1-1/2 turns out from the seat. This is for engines WITHOUT K-19.
      Larry
      • Leif A.
        • August 31, 1997
        • 3650
        Duke,
        Rich and Larry are absolutely correct.
        Leif
