C2 headlight door adjust - NCRS Discussion Boards
  • E R.
    • December 1, 1987
    • 17
    Is it possible to adjust the C2 headlight doors from side to side to even the gap?
    EV
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11323
    Re: C2 headlight door adjust
    EV, The inner side Y-Stop arm and the outer Ring can be loosened and adjusted horizontally to center the bucket in the opening.
    To adjust the Y-Stop, loosen the pinch bolt(7/16" wrench). To loosen the outer ring requires a Allen wrench(1/8" or 3/16" IIRC). When both are loose you can move the bucket horizontally into position, then snug both Y-Stop pinch bolt and Ring setscrew. This is usually trial and error.
    The hardest part of this adjustment is getting hands and tools in there. If the hood is off it's much easier. If hood is on, place a 1/4" bolt in the Hood Support arm alignment hole to ensure human arm safety.
    I must warn you, it's not a fun task and a back brace may help save pain.
    • Gary H.
      • September 18, 2018
      • 69
      Great post. Exactly the simple clear answer I was looking for. Thanks
      gary...
      1967
      Convertible, L79 327/350hp, M20, Marlboro Maroon (sort of) / Saddle
