best mildew killer - NCRS Discussion Boards
best mildew killer
  • William F.
    • June 9, 2009
    • 1364
    best mildew killer
    What's best product to kill mildew on vinyl seats/ upholstery without harming it?
  • Ed S.
    • August 6, 2014
    • 1377
    Re: best mildew killer
    Killing mold spores and cleaning the black stains they deposit are two different things. Bleach or a water &bleach solution does a good job at both but it may fade the color of the vynil. Ultra violet light will kill the spores. Soap and water will wash off the black residue if it is on the surface of the vynil. If it is down in the pours of the.vynil you may never get it out
    Ed
    • Larry E.
      • 1692
      FWIW>JMHO>Household Vinegar does it for me. Harmless to material and smell goes away in a day or two.
      Larry
      Larry
      LT1 in a 1LE -- One of 134
      • William F.
        • June 9, 2009
        • 1364
        Full strength white vinegar or diluted?
        • Larry E.
          • 1692
          I use white vinegar with a 50-50 mix. On stubborn stains I have used it full strength with good results. Larry
          Larry
          • William F.
            • June 9, 2009
            • 1364
            Thanks, but to be clear it's not stains, it's the white powder, guess it's the spores. Need to kill it. Lysol? Boat upholstery mildew product ( but it says "stain remover")
            • Jeff W.
              • December 20, 2015
              • 101
              I've had the best success using Starbrite Stain Remover to REDUCE the staining. Walmart in the boating section of a superstore. <$10. For killing the stuff, 50:50 mix of 100% ethanol and water, soaked in it for 30 minutes if possible. I literally filled my seats with this 'cocktail'. Home Depot sells 100% ethanol as denatured alcohol. I found it much more effective than bleach, peroxide, and an enzymatic killer.
              • Patrick C.
                • January 16, 2013
                • 327
                I always have a box of baking soda open in the car when its in storage. Kills the mildew smell.
                • David M.
                  • September 30, 2004
                  • 526
                  Try Concrobium. Its available at Home Deep Hole. This product is 99.5% H2O and ~.5% Trisodiumphosphate. Follow the instructions. Bleach doesnt kill the spores neither does vinegar. This stuff gets down to the spore and kills it dead! I've used this product with 100% success. I use it on everything from my pool diving board to cellar block foundation to snow mold roof stains on asphalt roofing shingles.
                  Concrobium products absorb moisture and stop and prevent mold and mildew. Find mold and moisture removers and other solutions.
                  • Larry E.
                    • 1692
                    FWIW>
                    Vinegar is a mild acid which can kill 82% of mold species. (Baking soda is often used along with vinegar for killing different species of mold.) To kill mold: Use white distilled vinegar and pour it into a spray bottle without watering it down. Spray the vinegar onto the moldy surface and leave it to sit for an hour. Take your pick on the various solutions you have heard. Larry
                    Larry
                    • Patrick B.
                      • August 31, 1985
                      • 2003
                      David-- I just tried Concrobium spray Mold Control on the woven 1970 seat material that seems particularly susceptible to mold and it worked great. No smell or danger of bleaching the color. Thanks for the good tip.
                      • David M.
                        • 526
                        You're welcome!
                        • Mike F.
                          • April 25, 2011
                          • 668
                          Are you sure it just isn't the seat cushions breaking down from age and making a white dusty powder? I see that on early C3 interiors quite a bit.
