need some 1959 power top info. - NCRS Discussion Boards
  • Stephen R.
    • May 20, 2008
    • 302
    Does anyone know the size of the brass fittings that go between the hoses and the pistons on the 1959 power top set up? Where can I get them? I need three.
    I have a complete set of original hoses, the fitting on the long hose that goes to the bottom of the driver side piston is broken at the piston end, can this be repaired? Can I get just that one hose? can I get that fitting? If so, where?
    Thanks for the help.
    Steve
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11366
    Re: need some 1959 power top info.
    Steve, Maybe 2 options.
    Try to locate a shop that makes hydraulic hoses. My local NAPA can do that.
    Contact John Schell, who restores these systems. He has a supplier that makes the hoses and may be able to get you just that one hose or the fittings.
    John Schell
    vettelink@aol.com
    260-749-8201
    Rich
    • Stephen R.
      • May 20, 2008
      • 302
      Rich:
      Thanks for the leads. I'll try the local NAPA first.
      Steve
