Lift Points 62 - NCRS Discussion Boards
Lift Points 62
  • Ed P.
    • August 10, 2014
    • 89
    Lift Points 62
    I just received my Quick Jack unit and i need to know where the left points are on my 62.?
    edd
  • Hal E.
    Infrequent User
    • April 1, 1985
    • 21
    Re: Lift Points 62
    I would think they should be the same as if you were using the jack. Believe recommended jacking points appear in the owners manual and or the ST12. Only difference is you are picking the car up in four places instead of each wheel individually. BTW my Quick Jack(5000 pound model0 works well....
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11323
      Re: Lift Points 62
      I'm not familiar with that lift, but when using my 2 post, 4 arm lift on C1's I always position the arm pads at each of the 4 outer corners where the X-Frame meets the outer frame rails. There is a triangular area at each which allows the pads to contact the frame perfectly flat.
