1955 wiper switch and cable - NCRS Discussion Boards
  • Ronald R.
    • May 31, 1989
    • 671
    My 55 had a 56 switch and cable, all the switches I can locate have one or two vacuum lines and a push button knob. I saw one that looked correct in Carlilse but turned out to be a 56 or later switch that had been plugged and altered to appear correct. Is this the best I can expect? Any picture of correct knob and switch would be appreciated. thanks For any help. Ronnie
  • John S.
    • July 29, 2009
    • 640
    Re: 1955 wiper switch and cable
    Originally posted by John Scopelite (50653)
    if it was a 56 it would not have been plugged.
    • Ronald R.
      • May 31, 1989
      • 671
      Does the knob have the push button? or blank or just the hole? thanks Ronnie
      • John S.
        • July 29, 2009
        • 640
        Blank with a setscrew
        • Ronald R.
          • May 31, 1989
          • 671
          Ok I thought this is what I was looking for! I have had no luck anyone know of one? thanks Ronnie
          • John S.
            • July 29, 2009
            • 640
            55 cable length is 28 5/8". 56/57 has the same body and stem with a 35" cable. 56/57 are available.
            • Ronald R.
              • May 31, 1989
              • 671
              Thank you, I can get the cable changed. Are these OEM or reproduction? And doyou know who might have one? thanks ronnie
              • John S.
                • July 29, 2009
                • 640
                Yesterday I received a email from corvette central. In it they have a section called "Swap Meet". Go to item #3724062 and you will find gm cable #3724062. Let me know where you send the switch to have the cable replaced and how much they charge.
                • Ronald R.
                  • May 31, 1989
                  • 671
                  thanks Jay M can do it shorten your for $35 or $60 for new
                  • John S.
                    • July 29, 2009
                    • 640
                    Ron, it's a good thing you did not delay on purchasing the wiper switch from CC. There appears to be some 56 owners that have been looking for that switch for quite a while. I had always looked at the switches I have with 35" cables as backups for 55s.
                    • Bob W.
                      • December 1, 1977
                      • 802
                      Ron Who is Jay M and does he repalr all c1wiper switches or just 53-55 parts?
                      Bob
                      • John S.
                        • July 29, 2009
                        • 640
                        Bob
                        Jay Maxwell, Capital Restoration, all C1 wiper parts
                        • Ronald R.
                          • May 31, 1989
                          • 671
                          thanks for the heads up!
                          • Tyler T.
                            • August 31, 1981
                            • 282
                            Try:
                            T 17470 Vacuum Wiper Motor Switch For 1955-1956-1957 FordThunderbird
                            Looks to be the same. I have both cars.
                            Tyler
                            • John S.
                              • July 29, 2009
                              • 640
                              Originally posted by Tyler Townsley (4814)
                              Try:
                              Tyler
                              Even the closest Ford wiper control switch will have two items(aside from the cable) that will be different than a 55 or 56 Corvette switch.
