1958 door small access plate - NCRS Discussion Boards
  • Howard H.
    • January 10, 2007
    • 139
    Is the small access door plate unique to 58? The door has 4 mounting holes for the plate and the original access plate I have has only 2 holes and they are in a different position than the holes on the door. The reproduction I see being sold look like what I have. Any help or pics would be appreciated.
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11334
    Re: 1958 door small access plate
    Howard, I suspect the 2 original holes in the opening were sawed out from the screws over time, so someone added 2 more holes to secure it.
    It's a common problem with those cover plates. I often install U-Nuts on the opening holes to get the cover plates attached using the original holes.
    • Howard H.
      • January 10, 2007
      • 139
      Thanks, Richard;
      That could be. It looks like only two of the holes have been used. However, the holes in the plate are in a different position than the holes in the door. If you are looking at the access opening the holes are on the left and right side of the opening. The holes in the plate are on the upper and lower edge. Could it just be a flat plate, without the lip that fits inside the opening?
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11334
        Originally posted by Howard Hiller (46797)
        Thanks, Richard;
        Howard, I found one photo of a '59 with the small access plate attached. You can see the screws at the upper outer corners. These were original plates. The other photos are to show the U-Nuts that I used on the large plate.
        • Howard H.
          • January 10, 2007
          • 139
          Thanks, Richard for the pics. Good idea to use Unuts.
