On 1967 F-40/41 rear 7 leaf spring was there a small flat spacer that went under differential then the spring was bolted up to it
1967 F40 rear 7 leaf spring spacer
Re: 1967 F40 rear 7 leaf spring spacer
my original l71with f41 car doesn't have spacerMichael
70 Mulsanne Blue LT-1
03 Electron Blue Z06- Top
It almost looks like someone cut the top leaf as there are only 6 leaves on that one you pictured. Or it may be a non original and someone added a spacer to get proper overall thickness.
Here is a '67 F41 for reference.
- Top
Rich,
Is that Lonoclad (the gray) you painted the leaves with or is that just gray paint trying to reproduce what was never there? Or just maybe trying to keep them from rusting?
The Lonoclad was applied to the bottom of the spring leaves to possibly stop noise? Never thought too much about that. Thought the liners were there to keep the noise down.
You just trying to simulate the sloppy work done by the St. Louis workers I guess by painting the entire spring?
JR
- Top
I wonder if they included that spacer due to thinner leaves and to ensure original length bolts would not break the differentials.
Jr, No just Rustoleum gray to protect, not meant to be "typical". Hmmm, sloppy? I thought they looked kinda "concours".Rich,
JR
It did get a hit in judging of course.....too "shiny". Of course the sheet said NTFP.
Rich- Top
That looks alot better thanks for sharing the photos Richard, was just wondering about that top spacer if it was factory or not and also didnt they remove the plastic liner between leaf 6 and 7 on the F40/41 spring by NCRS judging standards.- Top
- Top
