turn signal problem - NCRS Discussion Boards
turn signal problem
  • Bruce W.
    • June 30, 1997
    • 360
    turn signal problem
    Electrical one of my least favorite problems. I was adjusting my turn signal due to it not staying on in one direction. I could manually move the switch and each light worked fine. Then I lost all power to the switch. checked: no fuses out. checked the power where the wires go into the steering column to see if I had power there. Nothing!! would appreciate anyone's help. this makes no sense to me.
    Bruce
  • Chris S.
    • January 1, 2000
    • 1068
    Re: turn signal problem
    are you using a C Central switch? They are not of the highest quality and are known for issues. switch may be bad
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11364
      Bruce, The feed is the Yellow wire which comes from the Flasher, which is fed by Pink from the IGN switch.
      Key off or bad flasher.
      Rich
      ps This is the wiring for the later C1s but it may help diagnose. IIRC same switch for earlier C1's
