C-2 under dash mystery wires - NCRS Discussion Boards
  • Jim S.
    • March 1, 1986
    • 1408
    I know I will feel foolish when I get the answer , but give it to me anyway !
    I think the heat and the cramped quarters are getting to me , as I re-install the gauge cluster !
    What is this set of wires for ?
    Jim
  • Rick N.
    • August 25, 2017
    • 141
    Re: C-2 under dash mystery wires
    Blower motor switch.
    • Thomas S.
      • February 7, 2016
      • 618
      Orange/yellow/blue on my 63 goes to the heater switch
      67 427/400 Lynndale Blue Corvette https://online.flippingbook.com/view/750924569
      • Brian M.
        • February 1, 1997
        • 1842
        Get Dr. Rebuilds OOOH SOOOO Easy wire diagram charts they are a MUST Have. JMHO.
        • Larry E.
          • 1698
          Just a guess>Could it be the wires for the radio and speaker? I assume they where there even if is a non-radio car.
          Does your car have a radio?? Larry
          Larry
          LT1 in a 1LE -- One of 134
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11364
            The 3 terminal plug is definitely for the Heater Switch, as well as 1 of the 2 BRN Accessory plugs.
            I don't have access to a 1966 AIM, but I believe the extra BRN Accesory plug is for C60 Air conditioning if equipped as it would plug into the feed for the C60 Fan control switch.
            • Jim S.
              • March 1, 1986
              • 1408
              Hi guys and thanks for the replies.
              Yes my car has a radio and A/C .
              The blower switch was my first thought as well , however I already have the same colored wires wrapped in green tape marked as blower motor switch in a bundle of wires just above this one . The difference being that there are two orange wires for the same receptacle , and it does not have the two brown accessory plugs. (see photos)
              I should point out that I installed and labeled all new wiring harnesses t/o .
              Could this be another example of the stock wiring harness having a fan plug , but when A/C is added it goes unused in favor of the additional A/C harness ? If so I still wonder about the two additional Brown accessory wires.
              That Doc Rebuilt Chart sounds like a good Idea.
              Jim
              • Rick N.
                • August 25, 2017
                • 141
                The plug you showed is for the blower switch.
                All dash harnesses have this plug.
                Now that you have mentioned having A/C means you have a separate harness for A/C.
                The plug that is in the dash harness will no longer be used and you will be using the plug from the A/C harness.
                You will also not use the wire in the engine e harness that goes to the blower motor.
                Now you will use the wires from the A/C harness.
                Brown jumper harness plugs into brown wire in dash harness. This is how you will get the 12v to power blower switch with A/C
                • Jim S.
                  • March 1, 1986
                  • 1408
                  Rick ,
                  Looks like I was coming to that conclusion and editing my post at the same time that you were writing your reply. Thanks for confirming !
                  Do you have any info on what goes to the two additional brown receptacles ?
                  I will continue to scan the AIM in the C-60 section as well .
                  Jim
                  • Rick N.
                    • August 25, 2017
                    • 141
                    Brown wire plugs to terminal on switch.
                    The brown jumper off of wire to switch plugs into brown wire in dash harness.
                    This is how the switch receives keyed 12v to operate.
                    • Jim S.
                      • March 1, 1986
                      • 1408
                      Thanks Rick ,
                      I finally found it in the AIM ; UPC C-60 E8
                      The C 60 section is a book unto itself !
                      Jim
