Blower fan runs after ignition is turned off - NCRS Discussion Boards
  • Jerome P.
    • October 22, 2006
    • 607
    Recently I used the AC on my '72 LT1 with the blower on high. When I turned the ignition off the blower motor continued to run for maybe 30 seconds. I don't think I have ever noticed this before. Is this suppose to happened and I just never noticed it or is something else going on?
    If it is something else, does anyone have any suggestions as to what is happening?
    • 6950
    Re: Blower fan runs after ignition is turned off
    Jerome
    It sure sounds as thought the high blower relay is sticking. I would try and remove and clean the points internally with a piece of sandpaper or small file. the metal housing has a few tangs that can be bent to remove cover and access the contacts to be cleaned.
    • Jerome P.
      • October 22, 2006
      • 607
      Thanks for the feed back Ed.
      I have looked for the high blower relay on the car and also on a '72 electrical diagram and I m not finding it. Do you know where it is located or does it go by another name?
      again thanks.
      • Paul D.
        • September 30, 1996
        • 491
        My 71 AIM shows it mounted to evaporator housing out under the hood. Not sure if 72 is the same. Chip.
          • 6950
          Jerome, Chip is correct, should be a silver colored rectangle housing.
