clutch pedal return spring - NCRS Discussion Boards
  • Bruce W.
    • June 30, 1997
    • 358
    Hey guys, Need a little help! spring popped off and I am having trouble getting this back on. I sure there is a way but I haven't found the answer. thanks
    Bruce
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11320
    Re: clutch pedal return spring
    Bruce, See THIS thread and in Post #3 Frank attached a PDF with some good info to help.
    Rich
    • Dennis C.
      • June 30, 2002
      • 884
      Bruce,
      The procedure is in the ST-12 manual. Use a large adjustable wrench as a lever and it's relatively easy task.
      Dennis
      • Bruce W.
        • June 30, 1997
        • 358
        Dennis, thanks I will give a shot
        Bruce
        • Ray C.
          Infrequent User
          • March 1, 1995
          • 18
          Bruce, There is an article on RareCorvettes.com called 56 to 62 clutch spring replacement that will show you how to make a jig for replacing the clutch spring safely.
          I made one from a few things from Lowes and was pleased how easy it was.
          • Frank D.
            • December 27, 2007
            • 2703
            Some pad the spring coils full of fender washers to expand it. Then install it and push the clutch in and the washers fall out...
            NONE of that is necessary - not washers nor special jig. I've even know of one case where an owner used a "come along" and ruined some paint.
            A simple crescent wrench will get it on or off in a few minutes...
            • Jim D.
              • 2883
              Originally posted by Dennis Crupi (38211)
              Bruce,
              Dennis
              This procedure was written by Chevrolet over 50 years ago. It takes only a few seconds to install the spring by following them. There's no need to re-invent the wheel.
              • Dennis C.
                • June 30, 2002
                • 884
                And it's safe.
                • Bruce W.
                  • June 30, 1997
                  • 358
                  Dennis, couldn't figure how to get this spring on. took your advice and looked at ST 12 and found out it was never attached correctly. there was no hair pin to attach it to. Spring was hooked on the top of the bracket. No wonder it came off. when on easily once I had the correct hardware. Thanks for your help.
                  Bruce
                  • Dennis C.
                    • June 30, 2002
                    • 884
                    Bruce,
                    Glad it worked out.
                    Dennis
                    • Keith R.
                      • August 31, 2001
                      • 660
                      Second that!
                      And it's safe.
                      Keith MacRae
                      NCRS #36692
                      New Mexico Chapter
                      1960 290HP FI
                      2013 427 Convertible
                      Shade tree mechanic and
                      B-52 pilot extraordinaire
