Carpet Installation - NCRS Discussion Boards
Carpet Installation
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11323
    Re: Carpet Installation
    Dan, Looks really nice.
    That driver side flap near the sill step is EXACTLY the same problem I had with those '59 ACC Carpets from 5 years ago.
    In one case, I sent them back with my old carpet set and they fixed it. This was on my own '59. I found my records from 2009.
    The second case had the same problem but the set went in a hotrod '59 dragster so it had to be cut up anyways.
    The third case, shame on me, I had the EXACT same problem on a '59 body off restoration, and I fixed it myself. I had to remove sttiches, cut the excess, then restitch it.
    I never bought another ACC C1 carpet set ever again.
    Here are a group of photos showing the problems from my '59. As you can see the still step area was too long.
    • Dan D.
      • November 5, 2008
      • 1323
      Well Rich, that explains it. I bought this over 5 years ago, so I own it. I will try and fix it. Interesting you removed the stitches and re-did it. Don't know if I am that clever, but it looks like I am going to have to at least try.
      Your heal pad is also red. So I guess either this is correct, or all of them are wrong.
      As you can see I finally got pics to load.
      -Dan-
