Should 1961 trunk stowage foam pads be painted? - NCRS Discussion Boards
  • John G.
    • September 24, 2013
    • 245
    For 1961/62 the TIM&JG discusses that the clips and rivets were painted trunk color but doesn't discuss if the foam pads were painted? What's the answer?
  • Mike E.
    • February 28, 1975
    • 5141
    Re: Should 1961 trunk stowage foam pads be painted?
    The only foam pads I am aware of were on the bottom of the trunk plywood. They were attached to the already-stained plywood, so the answer is "no".
    • John G.
      • 245
      There are three pads for the handle and jack. If they were installed after the paint process then I'm assuming they should be unpainted.
      • Mike M.
        • May 31, 1974
        • 8400
        maybe the OP is citing the Rubber, not foam, pieces that glue to the trunk floor pan where the lug and jack wrench install. . mike
        • John T.
          NCRS Financial Officer
          • January 1, 1983
          • 292
          The pads glued to the trunk floor for the jack handle and lug wrench were not painted.
          John
          • John G.
            • 245
            Thanks for the info. I'll remove the painted ones. Any spec for these "high-density foam rubber pads" such as width or thickness?
