1967 Inner Fender Bonding Photos - NCRS Discussion Boards
  • Donald W.
    • August 12, 2013
    • 190
    Can someone post some photos of the Inner Fenders where they are bonded (Glued) to the inside of the Park Light Panels. The curved portion of the Inner Fender @ the front inside edge (maybe a photo try also from inside the grille area also). Tough area i know to try and get a photo.....Thanks to all...Don
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11364
    Re: 1967 Inner Fender Bonding Photos
    Don, Some of a '67 here and a few more of same car below. I can't recall some of the angles taken of some but you may be able to match up locations.
    Rich
    • Donald W.
      • August 12, 2013
      • 190
      Great pictures....can you get in a little closer from inside facing back of Park Light and a little above that area where the skirt cups around the inside of the park lamp panel so i can see how much bond is in that cup area and if you can on the grille side where the skirt cup passes behind the edge of the front of the park light panel (has a square like indent there) passes behind the edge to the cup.....hope that makes sense....and thanks so much for taking the time for this as this is all i need to finish the bonding in those area's on both sides.......Thanks again Rich....Don
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11364
        Don, Sorry that's all I found from my files. Car all done and far away.
        • Donald W.
          • August 12, 2013
          • 190
          Thanks again Rich.......
          • Steve S.
            • April 2, 2017
            • 10
            This one help?
            • Donald W.
              • August 12, 2013
              • 190
              Yes....Thanks so much, Don
