Rusty Rotors - NCRS Discussion Boards
Rusty Rotors
  • Frank K.
    • January 1, 2000
    • 319
    Rusty Rotors
    What can you do to prevent the rust and is there a compound to retard this rust? How would you clean them ?
  • Leif A.
    • August 31, 1997
    • 3648
    Re: Rusty Rotors
    Frank,
    Nothing will prevent rust from forming on the surface of a rotor. The minute water hits the surface, oxidation begins. The best way to prevent serious rusting of the surfaces is to drive the car on a regular basis. I don't know the current condition of the rotors you're asking about, but if this is for a project car that has been sitting for an extremely long period of time with severe rust, a light cut on a lathe should remove the heavy rust. There is no chemical treatment that I am aware of that will stop rotors from rusting.
    Leif
    • Michael W.
      • April 1, 1997
      • 4290
      Re: Rusty Rotors
      C2/C3 rotors must never be separated from their spindles/hubs for machining. Doing so invites the possibility of lateral runout.
      There are no coatings or sprays to reduce the corrosion as these would contaminate the brake pads.
      • Leif A.
        • August 31, 1997
        • 3648
        Re: Rusty Rotors
        Originally posted by Michael Ward (29001)
        C2/C3 rotors must never be separated from thier spindles/hubs for machining. Doing so invites the possibility of lateral runout.
        Michael,
        I concur. That's why I said "I didn't know the current condition" of the car. It could be in baskets for all I know.
        Leif
          • 43263
          Re: Rusty Rotors
          Frank------
          Assuming that you're talking about the brake pad contact surface of the rotors, light rust need not be cleaned----the brake pads will clean them in very short order when the car is driven.
          For more severe rusting, 3M offers a brake rotor reconditioning kit. The kit consists of special abrasive pads with mandrels that are used with an electric drill. These will remove the rust from the rotor and impart a non-directional finish. They work VERY well. You would need to obtain this kit from an automotive supplier.
          If rotors are severely rusted with pitting I would recommend replacing them.
          • Frank K.
            • January 1, 2000
            • 319
            Re: Rusty Rotors
            They are rotors new that are rusty in a box. I will check for pitting and the three m kit. Thanks Frank
              • 43263
              Re: Rusty Rotors
              Frank------
              For new-in-the-box rotors, unless they've been stored in a very wet environment there should only be surface rust. In that case, the 3M kit should work perfectly.
              • Michael W.
                • April 1, 1997
                • 4290
                Re: Rusty Rotors
                The 3M kit works very well for this and is available at the retail level. Walmart or Amazon.
                3M part number 01410
                • Gene M.
                  • April 1, 1985
                  • 4232
                  Re: Rusty Rotors
                  Easy solution is drive the car often..........
