Working on my 67 327/350 L79 engine I was replacing the hose from the Carb to the PCV Valve /Oil Fill Tube and noticed that the hose id was smaller than the PCV connection nipple, it could be forced on but is a tight fit. Checking further I noticed the PCV valve was a CV- 590C, checking with parts catalogs it should be a CV-726C. Looking further into it noticed checking the CV-590C check valve operation it seemed to be checking in the wrong direction.
My understanding of crankcase ventilation is the hose connects to the carb and the manifold vacuum sucks the fumes from the crankcase through the PCV into the carb to be burned in the combustion cycle.
I ordered a CV-726C PCV and when it arrived sure enough the nipple was the right size but more importantly the check is going in the right direction. My guess is that someone years ago had a CV-590C PCV on the shelf and just put it in thinking it was just the hose connection difference which could be forced on, not knowing the check operation was backwards.
So now my 327/350 is breathing a lot better.
All PCV valves are not created equal.
