Wiper door trim rivet - NCRS Discussion Boards
  • Mathew S.
    • July 9, 2015
    • 137
    My wiper door trim rivet on one side of my 70 went missing at some point in life. From looking at the little bit that I can see it looks similar to the press in rivets for the oil splash shield on the bottom of the intake manifolds. Anyone have a picture of what the rivet type thing actually looks like?
    I'm think something like this (likely different size) at be what was there originally. https://www.fastenal.com/products/de...0Screws%22%7C~
  • Russ S.
    • April 30, 1982
    • 2163
    Re: Wiper door trim rivet
    You are correct Mathew and it is smaller but same style. A friend of mine found them recently for his car. let me know if you can't find them and I will check with him as to where he got his rivet.
      • 15640
      They are called "drive rivets" I would suggest McMaster Carr.
      • Mathew S.
        • July 9, 2015
        • 137
        Does someone know the correct Size? Drive screws seem to be closer, based on the images that I have found. The drive rivets have a raised center protrusion. They may be interchangeable as well in terminology.
