I am getting my 1964 fuelie (380 unit) ready for judging. My mannuals are a bit vague on how to adjust the high idle speed. I am worried about passing the ops check. Could somebody give me a few pointers on how to adjust the high idle operation?
Currently the high idle is a little erratic. On a cold start sometime it works and sometimes it does not. When it does not work i have to give it gas until its warmed up a bit..Rich/Lean adjustment? I thought this might also be a result of the 90 degree weather? When it does work the engine high idle speed is only about 1200 RPM and a bit rough. The manual says it should be 1800 RPM. My warm idle speed is stable around 850 RPM. I cannot seem to reach the high idle screw under the air valve. Any suggestions on how to adjust that screw without removing the air valve?
Any help would be appreciated.
Pat
Pat
