Background: 1974, L48, manual, conventional points ignition, uniset point set new installed today as part of troubleshooting. Last used about 3 weeks ago and started and ran normally. No start today. Battery and starter strong. Car has a history of consuming points in a few hundred miles which is why the new point set was installed. Never have found the cause for this but did change out the starter solenoid a year or so ago so see if that would help the point issue.
Troubleshooting done today: Tried starting ether - no response, measured full battery voltage at plus side of coil when ignition switch turned to on ( not sure this is correct?) , continuity of black wire from minus side of coil to points checked ok, verified that new points are opening and closing via a VOM continuity check while turning over on the starter, cap and wires appear like new (don't know the age but not many miles), pulled number 1 plug and put on a spare spark plug - wife said she saw little to no spark when I cranked the engine - not sure what to make of that.
I am beginning to suspect the coil may be bad as I think it is original to the car.
Looking for ideas of where to go next?
