I am looking for information on rebuilding my oil pump (or finding a replacement) for my 63 340 HP vett. Any information appreciated
63 340 HP oil pump
Tags: None
- Top
Re: 63 340 HP oil pump
It's easy to inspect and rebuild as long as it has never ingested a bunch of debris. Remove the four screws, cover, and gears. Inspect the gears and housing for damage. Any wear on the endplate can be dress down with some wet 220-400 paper on a flat surface. It's also a good idea to inspect end play. Dress down the housing and one gear to acheive about two thou.
Normal 340 HP hot oil pressure is 40-45 psi at 2000, and as long as it produced this pressure prior to disassembly there is no need to replace the spring.
There are no gaskets... either between the endplate and pump body or pump body to block, so if all is well it's no more than a little bit of time
Most used oil pumps are perfectly serviceable, but usually get replace..., most of the time with a "high volume" pump that generates too much pressure.
Don't drink the Koolaid.
Duke- Top
Thank you for the detail. Since I would be removing the pump I would like to replace the spring. Any thoughts on where I might find one?
Rich- Top
Real easy.
1963 used two different oil pumps but the only difference between them was the installed oil pressure relief spring. You can determine which one you have by simply looking at your oil pressure gauge.
If the gauge shows a maximum oil pressure of 60 PSI, use spring GM #3814903
If the gauge shows a maximum oil pressure of 80 PSI, use spring GM #3848911
Both springs are still available from GM at a modest cost.In Appreciation of John Hinckley- Top
Thanks Joe. I had no idea that the spring would still be available or appropriate part number. But also, did not realize that there was an 80 psi unit. I had not seen one of these.
Rich- Top
If you want to find out more about GM 3814903, take a look at this thread:
There is a link there to a PDF I created that has an engineering comparison of the 3814903 spring and several Melling springs that some people have used to substitute for the 3814903 spring. Which can and does lead to excessively high oil pressures. In my opinion, there simply is no equivalent to GM 3814903 in terms of the stiffness and force/deflection specifications. Which ultimately leads to oil pressure differences if using an aftermarket spring instead of GM 3814903.
Gary- Top
