What is the maximum over-bore size for a '65 396 cubic inch cylinder bores. This is the original 962 block that the car was bore with.
Why I ask is that "Bubba" performed a .030" over-bore on the block back in the 1980's but all of the bores are not the same size for the pistons that were installed at that time. The engine uses a large quantity oil and I'd like to go to the next larger over-bore size or have custom sized set of pistons made based on the amount of material that needs to be removed to get all the cylinder bores to the same approximate size.
More info to follow on the approximate cylinder bore sizes currently.
Any advice help would be greatly appreciated.
Best Regards,
James West
Best Regards,
James West
