My 62 327/340hp engine is undergoing its second rebuild. First was at 60k+ miles back in late 60s. An engine rebuilder installed Crowler solid lifters with a Duntov 30-30 cam. Now after another 60k+ miles, the engine was disassembled due to leaking head gasket to find that about 8 of the 16 Crowler lifters had come apart internally. Only thing holding the lifter guts in was push rods. The photo with two lifers are the Crowlers, one with the keeper coming out and the other showing the internal part that dropped out after extracting from engine block. Can't say what effect, if any, the lifters coming apart had on the valve train but I had never seen or heard of any solid lifters coming apart.
The other photo shows one original GM lifter that was factory installed in the engine back in 1962. All 16 of the lifers appear to be in good shape with no apparent internal problems.
Have others experienced this problem with Crowler or other after-market brand solid lifters. Will be in need of replacement lifters to go with an NOS 097 cam in the rebuild, so since over-the-counter GM solids are long gone, any suggestions on replacement lifters?
Also, any thoughts on the Crowler lifter problem?
Thanks, Larry
Thanks, Larry
