hydraulic throw-out bearing troubles - NCRS Discussion Boards
  • Mike M.
    • May 31, 1974
    • 8389
    i installed a 6.2L LS3 in my 05 silver ado 4 x 4. i then got a tremec t-56(aka transzilla) from rockland gear in new york. they use a Ram clutch set up . the tremec and the Ram setup requires a Ram hydraulic throw out bearing. i've got about 20K miles on this setup and have had to replace the throw out bearing three times. Ram says there is no heavy duty throw out bearing. when the bearing fails, the bearings in the throw out grenade. its a sealed bearing. i thought about using a slave cylinder and clutch fork and regular non-hydraulic throw out bearing but there is no way to install a throw out fork pivot ball in the adaptor between the tremec main case and the engine. i'm getting tired of pulling the exhaust system, transfer case, and tremec to replace these inferior hydraulic throw out bearings. any thoughts guys? thanks in advance, mike
  • Ed H.
    • November 1, 1999
    • 626
    Re: hydraulic throw-out bearing troubles
    Mike I would contact Whites Racing LLC in Florida he is very knowledgeable in C-4 and ZR-1 applications.
    • Timothy B.
      • April 30, 1983
      • 5186
      Mike,
      For me it's hard to picture everything without seeing it but replacing three bearings there is something wrong. Could there be a pull back spring or some means of allowing the bearing to release missing in the assembly.
