1955 washer reservior - NCRS Discussion Boards
  • Ronald R.
    • May 31, 1989
    • 670
    When did the 55's start seeing the bag in lieu of the jar? My car is 480 and has pump in the floor and bracket holes for the jar in the fender, ( no bracket, jar, or lid) thanks Ronnie
  • John S.
    • July 29, 2009
    • 640
    Re: 1955 washer reservior
    explain what you mean by pump. do you have a plunger(button style) or the higher foot pedal?
    • Ronald R.
      • May 31, 1989
      • 670
      foot pedal just up and right from dimmer switch
      • Ronald R.
        • May 31, 1989
        • 670
        Does anyone reproduce a correct jar lid and ribbed bracket? thanks Ronnie
        • John S.
          • July 29, 2009
          • 640
          does not seem correct for you to have a pedal. your car is too early unless a 3speed was installed. area you describe is also were the foot plunger is located. the washer bag and foot pedal start appearing between 1525 and 1550. washer jar and plunger will reappear later in the 55 run
          • Ronald R.
            • May 31, 1989
            • 670
            There is a pair of holes in the fender for the bracket and jar nothing in the area where the bag would hang. All original fiber glass. There is a hole in the floor next to dimmer no pump, just assumed it was for pump. thanks RDR
            • John S.
              • July 29, 2009
              • 640
              I see the lids occasionally on ebay. I only seen one 55 washer bracket for sale in the past ten years. I am even thinking the one in the judging manual might have been fabricated because I do not recall a 1/2" hole on the mounting side of the bracket.
              • John S.
                • July 29, 2009
                • 640
                the hole in the floor is for the plunger style pump which is correct for you car. By foot pedal I was talking about a lever style pump which is only used with a washer bag.
                • Ronald R.
                  • May 31, 1989
                  • 670
                  Is this the bracket I'm looking for? Seems to be a lot of opinions. thanks ronnie
                  • John S.
                    • July 29, 2009
                    • 640
                    that is the correct bracket.
                    • Ronald R.
                      • May 31, 1989
                      • 670
                      thanks
                      Ronnie
                      • John S.
                        • July 29, 2009
                        • 640
                        look up Jay Maxwell. even if he does not have an original bracket, I would think he would have parts to make one.
                        • Troy P.
                          • February 1, 1989
                          • 1284
                          Correct brackets are not impossible to find. Not as prevalent as the 54 bracket though. NOS washer jars and lids are available as well.
                          • John S.
                            • July 29, 2009
                            • 640
                            I have not seen a correct photo of a 55 corvette washer jar bracket in any corvette manual and that includes the NCRS judging guide. Even the picture of the bracket in Nolan's restoration guide is incorrect. Although the photo in Nolan's guide is incorrect, the dimensions given on page 33 are correct. Only the 1/2" hole on the lower part of the vertical bracket is not shown.
                            • Troy P.
                              • February 1, 1989
                              • 1284
                              Ronnie, call me next Tuesday when I get back from Pebble Beach. I can help you with the bracket and jar. 435-704-1419.
