087 Coil resistance comparison to 087 GM licensed reproduction. - NCRS Discussion Boards
  • Richard G.
    • July 31, 1984
    • 1718
    I also had a used 202 coil the type used in 1964, I took the reading on it also.
    Results below.
    The secondary winding of your ignition coil 087 OEM 087 reproduction 202 OEM
    Ohms Ohms Ohms
    Primary Winding 1.8 2.4 2.2
    Secondary winding 7.9K 11.71K 14.46K
    OEM
    Reproduction
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11334
    Re: 087 Coil resistance comparison to 087 GM licensed reproduction.
    Richard,
    Good reference data. Thanks.
    Rich
    PS sent you a PM
    • John D.
      • December 1, 1979
      • 5507
      Nice Job Richard, Big difference between the original and repro 087. Much appreciated. John
      • Gene M.
        • April 1, 1985
        • 4232
        So what do the differences mean in terms of operation and performance? Is it Good or Bad?
        • Ken A.
          • July 31, 1986
          • 929
          The higher the secondary the better the performance, up to a point. The 087 is a little bit weak, definitely for a base motor.
          • Gene M.
            • April 1, 1985
            • 4232
            So the 202 coil for normal driving would be a better choice of the three, disregarding correctness. Correct?
            • Ken A.
              • July 31, 1986
              • 929
              Not necessarily. The design of the points style ignition was to start with an optimum system and provide adequate performance over at least 12K miles while literally wearing out. The TI system fixed a lot of ignition problems but still wasn't up to the HEI. If not for emission standards, the TI
              would have lasted a lot longer, because it did not have the wear problems & operated at a much lower voltage. Remember, it only takes a few thousand volts to start the spark kernel, a 50K "blaster" coil is useless & will short out most SP wires.
