Radiator caps, what are you using? - NCRS Discussion Boards
  • Gary R.
    • April 1, 1989
    • 1798
    Curious to see what you guys are using for caps, I don't think the local stores have 15lb caps anymore. I can probably use a 16lb Stant cap on my base 350 72 if needed. My original is still fine, more curious then anything else.
    gary
  • Leif A.
    • August 31, 1997
    • 3627
    Re: Radiator caps, what are you using?
    Ac rc-26 15#
    Leif
      • 11643
      Leif shows a repro. In my experience, there is a moderate chance they won't work.
      You can pick up a current issue RC-26 which will work with no issues. The RC-26 is backward compatible to the RC-15, but I believe not the other way around. They work fine as "driver" caps.
      • Leif A.
        • August 31, 1997
        • 3627
        Patrick,
        I know the one I pictured is a repro but Gary was simply asking "what are you using". I've been using the pictured repro for 3 years with zero issues. You comment that "you can pick up a current issue RC-26..." Where is this available and what is the difference?
        Thanks in advance.
        Leif
          • 11643
          The current one has real OEM specifications, not "this should be close" specifications of the reproduction.
          I've had several repros fail on me and friends if the cars are driven any amount, and have lost faith in them. They're not even that accurate looking, so I don't waste my money.
          $18 for a new OEM part on eBay that functions well and lasts for years. Easy decision.
          • Gary R.
            • April 1, 1989
            • 1798
            Thanks guys, I was wondering how the basic parts store Stant brand were and if they had a 15 lb cap. They used to be good but it's been a long time since I needed to buy one. I doubt any of the local stores around here will have the ac caps in stock if I wanted to quickly swap one out.
            • Mark E.
              • April 1, 1993
              • 4536
              RockAuto shows nine caps available for a '70 454. Eight (including two AC Delco caps) are less than $4. The RC-26 "Professional" is 16#, hex-shaped and $9.23.
              Mark Edmondson
              Dallas, Texas
              Texas Chapter
                • 11643
                Yes, but you have to watch out for the shipping cost.
                In addition, based on photos (which from them are usually accurate) none of them are an RC-26. They are the same items you'd buy at AutoZone; they just rebrand them ACDelco.
                • Mark E.
                  • April 1, 1993
                  • 4536
                  ...they just rebrand them ACDelco.
                  What? RockAuto takes brand X and rebrands them ACDelco?
                  Or are you saying ACDelco just makes junk from China like most suppliers?
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
                  • Jimmy G.
                    • November 1, 1979
                    • 976
                    Delco new stainless service replacement caps
                    • Michael M.
                      • February 7, 2011
                      • 186
                        • 11643
                        ACDelco buys the aftermarket stuff, throws it in ACDelco boxes, and charges you more.
                        Actually, I suspect that the suppliers put their stuff in ACDelco boxes, and ACD never handles most of it.
                        • Mark E.
                          • April 1, 1993
                          • 4536
                          The cap design changed in '73 with the introduction of closed cooling systems. An upper seal was added (shown in your photo) to create vacuum during cool down, and the vacuum valve is calibrated differently. These caps will physically fit your '67 but aren't designed for an open system.
                          Mark Edmondson
                          Dallas, Texas
                          Texas Chapter
