Help Identify Neutral Safety Switch for 1966 BB with Powerglide transmission - NCRS Discussion Boards
  • Vincent A.
    Infrequent User
    • January 1, 2015
    • 24
    Hello all,
    I am looking for a Neutral Safety switch for 1966 BB with floor mounted powerglide transmission. No luck yet searching the internet for an original or compatible after market unit. Any help or advice would be greatly appreciated.
    Vince
  • Guest
    Re: Looking for Neutral Safety Switch for 1966 BB with Powerglide transmission
    uhm, this what you are looking for - https://www.ebay.com/i/390593573013?chn=ps&dispItem=1
    • Jimmy G.
      • November 1, 1979
      • 977
      What part number are you looking for??
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11364
        Rick, That one is for Passenger cars.
        Vince, 1993411 fits 65-67 and includes backup lamp along with neutral safety. If no BU lamps on your car then the wire connector is simply tucked away. This is one I had years ago but no longer mine. I had it about 8 years ago and paid about $300 then.
        Very hard to find and when found will be expensive. It is not reproduced. If your switch is defective it may be a viable option to try to repair it.
        If you don't have one, check these out, but it's going to cost you.
        1965-1967 Corvette Powerglide Neutral Safety Switch Original GM NOS 1993411 with harness lead. Four wire indicates it's for Back-Up Lamps also.
        (edit oops sorry I didn't notice it's SOLD.
        This one ended but you may want to contact seller if still available.
        • Vincent A.
          Infrequent User
          • January 1, 2015
          • 24
          Thanks Rick, I contacted the folks with that ad and was told that its not corvette compatible. The ad says it is and it isn't in different places. -Vince
          • Vincent A.
            Infrequent User
            • January 1, 2015
            • 24
            Thanks very much Richard. yes, that's it. I'll try your suggestions. - Vince
            • Vincent A.
              Infrequent User
              • January 1, 2015
              • 24
              Its GM part number 1993411 Jimmy. Thanks - Vince
              • Leif A.
                • August 31, 1997
                • 3654
                Have you tried David Sokolowski? He advertises in the Driveline...seems to have every imaginable Corvette part known to man.
                Leif
