1970 LS5 vacuum inHg at idle? - NCRS Discussion Boards
  • Siegfried K.
    • November 23, 2011
    • 29
    I finally have my 70 LS5 coupe on the road after 4 1/2 years of hard work, an awesome feeling of accomplishment I must say. I am running an RV cam, so it has a very nice idle. The engine is 30 over, stock heads with a very nice port and polish job, roller tip rockers, stock iron intake, stock rebuild on Quadrajet carb, and distributor has been upgraded to electronic ignition. Upgraded to a Dewitts radiator and billet aluminum high flow water pump from Meziere, runs nice and cool now even sitting for long periods of time. I have had it dyno'd at the crank, and it put out 435 hp and 550 ft/lbs of torque.
    My question is what is the factory vacuum "Hg spec for this engine at idle, 700 RPM, and at approximately 3000 RPM? I have around 15-16 "Hg at 800-900 RPM in neutral on the non ported carb outlet. I have not checked at the vacuum at the main manifold port as of yet. It also seems to run very well at 16-18 degrees of initial timing which seems rather high? I have no experience with big blocks until now, so I have nothing to compare to.
    Last edited by Siegfried K.; July 26, 2017, 01:02 PM. Reason: Additional information
  • Mark E.
    • April 1, 1993
    • 4597
    Re: 1970 LS5 vacuum inHg at idle?
    I don't recall a factory spec for vacuum at idle. My stock (not counting the ignition advance curve) '70 LS-5 pulls 17-19" at 750-800 rpm. This is with centrifugal @ 12 deg. BTDC plus full vacuum to the VAC.
    You have a different cam, so your results are probably different.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Mathew S.
      • July 9, 2015
      • 137
      Mine is pulling about 14" at around 800, running 8 deg BTDC, per the stock spec. I a, not sure the cam, as it was done by previous owner, heads were ported and polished, along with exhaust manifold entry.
