Last week I noticed a small amount of gasoline on the passenger side valve cover. Closer inspection showed a leak (drip) at the base of the fuel injection pump flange just below where the cable enters. Difficult to tighten the screws even with a 90 degree screwdriver. This is a 380 fuel injection unit. Do I need to pull the whole FI unit from the adapter manifold to reseal the flange? Any other suggestions to make sure i just do this once?
Pat
Pat
