1964 327/365 Intake manifold - NCRS Discussion Boards
  • Paul K.
    • February 1, 2002
    • 161
    A friend of mine just rebuilt his 64 327/365, he has bought the correct 3844461 Aluminum intake manifold, but there is no hole in the front of the manifold for the heater hose, According to my Chevy V-8 number book, this is correct for 327/365. Can anyone tell why there is no tapped hole?
    Paul Klemetson
    • 43277
    Re: 1964 327/365 Intake manifold
    Paul Klemetson
    Paul------
    I've never seen a 3844461 without the fittings for the heater hose nipple and the temp sender. Is there a boss for the heater hose fitting? If so, it could be drilled and tapped.
    • Paul K.
      • February 1, 2002
      • 161
      the temp sender hole is there, no boss for the heater nipple
        • 43277
        Paul------
        I don't understand this, at all. The boss for the heater hose fitting is part of the 3844461 casting. How one can have a 3844461 casting without the boss is beyond me. As a matter of fact, virtually all Chevrolet small block intake manifolds have provisions for the heater hose fitting. Some do not have provisions for a tamp sender.
        • Leif A.
          • August 31, 1997
          • 3653
          Post up a picture of the intake please.
          Leif
          • Paul K.
            • February 1, 2002
            • 161
            Taking a closer look, someone did weld the heater hose inlet shut, not sure why.
            Paul klemetson
            • Loren L.
              • April 30, 1976
              • 4104
              Did they also "weld" up the inlet/outlet for the 90 degree bypass that goes to the top of the water pump? Sounds like a helluva buy......
              • Paul K.
                • February 1, 2002
                • 161
                No the by pass is still there,
