63 fuel car - NCRS Discussion Boards
63 fuel car
  • Bob R.
    • June 30, 2002
    • 1595
    63 fuel car
    What HP engines could be ordered with a 3:08 rear in 63. The rear differential in my car is stamped CJ and correctly dated for my car. I believe it to be original to the car but wondered if it could be ordered for a fuel car.
  • Jack M.
    • March 1, 1991
    • 1195
    Re: 63 fuel car
    Here's a composite excerpt of '63 rear axle data from the FREE Information Kits available at the GM Heritage Center.
    If you are unfamiliar with these items, take a look at this old thread: CLICK HERE
    • Bob R.
      • June 30, 2002
      • 1595
      Re: 63 fuel car
      There was a lot of information there thanks for posting that. I noticed that there are two optional rear 3:08 gears one is noted as G81 and is available on 250 and 300 HP the other is G91 and is available on 340 and 360 HP. The Black Book notes that there were only 211 cars delivered with G91 but it doesn't note how to identify the parts any idea what CJ would be?
      • Jack M.
        • March 1, 1991
        • 1195
        Re: 63 fuel car
        On page #3 of the initial document posted, take a look at the top/right corner... CJ is listed as a Positraction Axle.
        Also, page #1 lists the G91 for 250 & 300 HP vehicles.
        In addition, this attachment illustrates the same info for G91:
        • Jack M.
          • March 1, 1991
          • 1195
          Re: 63 fuel car
          NOTE: Model info can change during the year... there is no guaranty regarding the data in these Info Kits (but nice FREE stuff).
          • Bob R.
            • June 30, 2002
            • 1595
            Re: 63 fuel car
            I do not follow you. G91 is noted as 250 and 300 HP with 4 speed and was a $2.20 option. G81 doesn't list the engines but is noted as a $43.05 option. I know that CJ is a 3:08 posi but I don't see any notation explaining if it is G91 or G81 and whether it was used for a fuel car.
            • Jack M.
              • March 1, 1991
              • 1195
              Re: 63 fuel car
              Hummm, maybe I'm confused (sorry - as I'm dyslexic). Let me revisit the data provided in the Info Kits.
              • Loren L.
                • April 30, 1976
                • 4104
                Re: 63 fuel car
                G91 is a non-posi 3.08 available with the wide ratio 4 speed that came with the 250/300 HP motors. If I recall correctly the '63 Z06 convertible that was ordered by the GM employee and discovered a few years back came with a 3.08 Posi - the owner called it a "contributing factor" to the number of speeding tickets he acquired in the first 18 months of ownership.......
                • Michael J.
                  • January 27, 2009
                  • 7167
                  Re: 63 fuel car
                  I have two C2s with 3.08 rear ends. My '64's (FI tanker) window sticker shows the 3.08 posi (2G81AA) a $43.05 extra cost option. I am not sure how many rear end ratios were extra cost options.
                  • Jack M.
                    • March 1, 1991
                    • 1195
                    Re: 63 fuel car
                    Perhaps those two statements are messing me up (they seem to contradict)... what engine do you think the G91 was associated with?
                    According to what I'm reading (and I'm NO expert), it appears the G91 was an open axle (3.08) available with the 250 & 300 HP engine ($2.20 option).
                    In addition, it appears the 3.08:1 positraction axle (G81) was a $43.05 option... and it was available with the 360 HP engine.
                    • Timothy B.
                      • April 30, 1983
                      • 5202
                      Re: 63 fuel car
                      I always believed that posi was a option and with posi you could specify any ratio. With the standard open rear you got 3.36 with wide box cars and 3.70 with close ratio cars.
                      • Michael J.
                        • January 27, 2009
                        • 7167
                        Re: 63 fuel car
                        In '63-'64 M20 was the only option in a manual Muncie.
                          • 15706
                          Re: 63 fuel car
                          G91 was an open 3.08 axle only available on 250/300 HP engines with M20. The standard axle was open 3.36. G81 was the optional Positraction axle available with all engines, 3.36 or 3.08 on 250/300 HP engines, and six ratios from 3.08 to 4.56 on 340/360 HP engines. As far as M20 was concerned if you ordered it with a 250/300 HP engines you got the wide ratio version, and CR with 340/360 HP engine. M21 came along in '66 when on some engines you could order either the CR (M20) or WR (M21).
                          • Leif A.
                            • August 31, 1997
                            • 3653
                            Re: 63 fuel car
                            Duke,
                            I'm sure you meant CR (M21) or WR (M20)
                            Leif
                            • Michael J.
                              • January 27, 2009
                              • 7167
                              Re: 63 fuel car
                              Yep, and there is nothing more difficult than getting a '63 or '64 Corvette with an M20, and one of the SHP engine, moving from a standing start on a hill with a 3.08 rear end.......
