FI engine manifold vacuum? - NCRS Discussion Boards
  • Bruce B.
    • May 31, 1996
    • 2930
    I have a 327 with a Corvette 151 (327, 3650 HP) cam in it which I choose for it's 114 LSA and its resultant high manifold vacuum.
    I also have a rebuilt stock 1957 283 CI 283 HP FI engine. My question is what amount of manifold vacuum can I expect from the FI engine?
    Also can someone tell me the LSA of the stock FI cam?
    Thanks.
  • Jim L.
    • September 30, 1979
    • 1817
    Re: FI engine manifold vacuum?
    Bruce, you can reasonably expect to see about 14" Hg manifold vacuum on that '57 engine if it has the 097 cam.
    Jim
    • Bruce B.
      • May 31, 1996
      • 2930
      Jim,
      Thanks.
      I am thinking of using the original 283/283 in my Gasser with my Hilborn EFI and I need a good MAP signal.
      So it should be fine.
      Bruce B
        • 15706
        L-79 cam 14-15" @ 750... Duntov cam about 12" @ 850-900. Both have about the same effective duration, but the Duntov LSA is 110.5 degrees, which means greater effective overlap and a more "lopey" idle. Thus the lower idle vacuum and higher necessary idle speed for reasonably stable idle behavior.
        For reference-
        LT-1 cam: about 12" @ 850-900 (about the same as the Duntov)
        30-30 cam: about 10" @ 900
        Base engine cam: 18-19" @ 500 (manual trans idling in neutral, a few inches less for an auto idling in Drive @ 500)
        The Duntov cam has been "obsolete" for a long time - symmetrical lobes, harsh dynamics, and insufficient lift for big port heads. For a road engine having it ground with the inlet POML at 110 deg. ATC and a 114 LSA would make it essentially a mechanical lifter version of the L-79 cam (except for the lower lift), which will improve low end torque without sacrificing top end power. Crane has Duntov lobe masters and can do the job.
        Also, as a reminder to everyone, specifying idle vacuum without including idle speed is meaningless because for any given cam, the higher the idle speed, the higher the manifold vacuum.
        • Bruce B.
          • May 31, 1996
          • 2930
          Duke,
          Very good info.
          Bruce B
          • John D.
            • December 1, 1979
            • 5507
            Bruce, With a Duntov O97 cam my '63 has 16" at 900 RPM. As you know the same cam was used from '57 to '63. John
            • Bruce B.
              • May 31, 1996
              • 2930
              John,
              Thanks.
              Bruce B
