Scan tool - NCRS Discussion Boards
Scan tool
  • Frank K.
    • December 31, 1999
    • 319
    Scan tool
    Scan tool does not link to dlc either key off or key in running position. Scan tool links to other vehicles make. Any suggestions welcomed ob1, c4
  • Keith B.
    • September 15, 2014
    • 1575
    Re: Scan tool
    What scan tool are you using.
    • Frank K.
      • December 31, 1999
      • 319
      Re: Scan tool
      Innova 3140e, and a actron cp9145
      • Ken A.
        • July 31, 1986
        • 929
        Re: Scan tool
        No codes-check for a bad CCM. Will car start?
        • Frank K.
          • December 31, 1999
          • 319
          Re: Scan tool
          Car starts runs fine until you shut it off then it is a long hard start
          • Keith B.
            • 1575
            Re: Scan tool
            If there is no service engine light I would check fuel pressure. And the fuel pump
            • Frank K.
              • December 31, 1999
              • 319
              Re: Scan tool
              There is a service engine lite
              • Keith B.
                • 1575
                Re: Scan tool
                Are all the fuses good
                  • 15575
                  Re: Scan tool
                  Pull the codes. They will help isolate the problem(s).
                  • Frank K.
                    • December 31, 1999
                    • 319
                    Re: Scan tool
                    Last time i checked they looked good.
                    • Frank K.
                      • December 31, 1999
                      • 319
                      Re: Scan tool
                      That is the problem it will not link (scan tool) with DLC (under dash) It tells me with two seperate tools bringing up codes is not possible. I just tested both tools with a different vehicle and it worked. These OB1 are not Gm best effort Its a hit or miss and you can throw a load of parts at it . Had the same problem in 1989 the Z24 would just die any where at any time!
                      • Keith B.
                        • 1575
                        Re: Scan tool
                        Do you know anyone local that has a professional grade older scanner like a Snap On referred to has the brick or a Mac. While the hobby grade scanner might work on some cars others cost more for a reason
                        • Frank K.
                          • December 31, 1999
                          • 319
                          Re: Scan tool
                          No! The last one i bid on e-bay i lost by $2.50 I will call around. Thanks
