Drive shaft U joint fasteners - NCRS Discussion Boards
  • Ed S.
    • August 6, 2014
    • 1390
    The correct part # for the U shaped bolts that are used on '64 drive shafts U joints is 1358938. Please see the attached pic.
    The bolt on the left is what I removed from my car, I am not 100% certain that it is original.
    The U bolt on the right is new, from LIC. Notice the thread size is considerably different. The LIC thread is fine, the one I took off my car is coarse. Also, the LIC bolt has a stamp on the outside top (on the crown) that reads "CEM" or "GEM". My guess is that the LIC bolts are not correct.
    Question is, does the U bolt I removed from my car look correct (the one on the left), and specifically does the thread size appear correct?
    Thank you,
    Ed
    • 43290
    Re: Drive shaft U joint fasteners
    Thank you,
    Ed----------
    The u-bolt on the left appears correct and the original u-bolts were coarse thread (5/16-18).
    • Ed S.
      • August 6, 2014
      • 1390
      Joe,
      As I suspected - thank you very much for confirming that for me.
      Ed
      Ed
