ok while looking at the water pump one sees the 4 main bolts holding the pump go thru the bracket (yoke type) supporting the engine.My question is by removing the water pump mounting bolts,will this cause the engine to drop down ?.
What would be the proper procedure to remove & reinstall ??
Francis
Francis
